How many outlets per circuit
Old 03-23-06, 09:17 PM
Hooter's Avatar
I am wiring my remodel and have gotten conflicting info. I am using #12 but will use a 15A breaker. How many outlet can I have on a circuit??
Old 03-23-06, 09:42 PM
bolide's Avatar
> How many outlets can I have on a circuit?
This is a house, right? How many do you like?
You should not put on more than will use 15A at any one time.
Since you have all #12 wire, why not change the breaker to 20A?
Old 03-23-06, 09:51 PM
Hooter's Avatar
I could change to 20A. I have been told that the NEC has a limit on the number of boxes but cannot find it in the code book.
Old 03-23-06, 09:54 PM
You were told wrong. It happens a lot.
I think a lot of people would agree with bolide that since you are using all #12, you might as well use a 20-amp breaker. There is no good reason to use a 15-amp breaker.
The answer to your original question depends on what country you are in. Could you please put your location in your profile?
If you are working on a residence in the United States, in most areas you are allowed by code to put 873 outlets on this circuit, plus or minus a few hundred. One rule of thumb (but not a rule of code) is to limit yourself to no more than 8 on a 15-amp circuit and 10 on a 20-amp circuit. But this rule of thumb can be adjusted up or down according to your knowledge of what will be powered from this circuit.
Old 03-23-06, 10:17 PM
Hooter's Avatar
Thanks John......It is in the US of A.... I had been using the 10 box rule but was told that 8 was max..... Thanks this has saved me alot of rework.......
