What Did I Do Now?
Old 03-28-06, 06:15 PM
stuemke
What Did I Do Now?
As was discussed in my other thread, I bought 14 gauge grounding wire (green insulated) and put a 6" piece from the grounding screw on the switch to the spun grounding wires in the back of my plastic recepticle box. I put on the last of the covers for the switches and outlets, went out to the garage, put the fuse back in position, and went back into the bedroom. I turned on the light switch...
And there we stood... in the dark.
I'm going to double-check all the connections, but I'm wondering if anyone has ideas of where I may have gone wrong. I labeled all the wires (ie. top, bottom, etc.) before tucking them in the boxes and then painting. When I installed the new switches and outlets, I made sure to put them back in the same spots (using the screws on the side and not the push pins on the back).
Any ideas will be appreciated! We're a little tired of not having light in that room (and in my adjacent bathroom, for that matter!!!).
Thanks.
-stuemke
Old 03-28-06, 07:39 PM
Are you sure it is a ground screw, and not the common terminal on a 3-way switch?
Old 03-28-06, 07:41 PM
You might have a ground touching a hot screw, from pushing the conductors back into the boxes. Take the covers off, peek in with a flashlight, and make sure you don't have any grounds close to the back of the devices.
If you don't see anything, check to be sure you don't have a white and a black on the same side of one of the receptacles. It's an easy mistake to make if you get in a hurry.
Old 03-28-06, 07:53 PM
stuemke
Arrrrgh...
I just double checked every single switch and outlet in the room to make sure I had the black wires and white wires on the right sides, connected the right way, all green insulated wires grounded in the right spots, etc. I can't seem to find anything wrong.
My wife did mention that she thought she heard a sound from a wall switch (single-pole switch for a basic closet) when I threw the power back on from the garage. Maybe the ground touched a hot screw? Would that make a sound? Would it ruin the switch? Could it throw everything that far off?
Maybe I should use a power tester tool (ie. the little tool with two wires and a light) to see if I've got power coming in at all, and which recepticle it's coming in to.
Last question before I let y'all go for the night: does it make a difference which screws (top or bottom) you attach the wires to on the outlets? I thought it did, so I labeled them all before dismantling. Maybe I'm missing something basic.
I'll check on the power tomorrow. I'm too tired to do it tonight... and too **** frustrated! *sigh*
Have a great night, everyone!
-stuemke
Old 03-28-06, 09:55 PM
bolide's Avatar
Maybe.
Yes.
Unlikely.
Did the breaker trip?
Yes.
Never saw one.
No, seriously, get the kind with just one rigid contact point.
Not unles the tab is removed.
You probably didn't check that.
Old 03-29-06, 07:31 PM
breaker test switch?
Did you install a new light fixture at the closet?
maybe you have the switch leg tied to the neutral and hot like a feed through device.
Then the switch would short the wires out when turned "on"
It happens ...
