#6 or #4 for generator
Your advice please. 15kw generator, 65 amp breaker on generator going into a 100 amp transfer switch with three #6 wires. Wiring from the manufacturer is #6 and includes a 4 foot run that goes into on outside box and a 30 foot run of #6 that goes from that outside box to the transfer switch. I need to run about 130' of wire to reach the transfer switch from the generator. Using a wire calculator I still come up with #6 wire, but would like your advice if #4 would be more appropriate? I don't want to rewire the #6 4 foot pigtail that comes from the generator if I don't have to. Also can I use #6 for the 4 foot run and then #4 for the 130 foot run?
Thanks
Thanks
Originally Posted by Flyinglow
There wouldn't be any issues going from #6 wire to #4 for the longer run?
I'll let the experts wade in but I'd also replace the 30 foot run up to the pigtail with #4 to minimize voltage drop.
That would probally make the most sense, I want to avoid having to take apart the generator housing and rewiring the pigtail if there is not any benefit or in this case detriment to leaving it as it is.
