Ground Rod for Sub Panel in Garage
Old 04-02-06, 05:30 PM
125amp sub panel in detached garage, 50' from house . . .
One or two ground rods?
1/2 inch, or, 5/8 inch?
#4 or # 6 ground wire to ground rod(s)?
Thanks!
Old 04-02-06, 05:48 PM
Speedy Petey's Avatar
One rod, possibly two. I typically install just one for such an application. Your inspectors may enforce two.
1/2" non-ferrous, or 5/8" steel/iron coated.
#6 is all that is required to a ground rod(s) alone.
Old 04-02-06, 05:52 PM
for subpanel most common to use one ground rod but few area might requried 2 rods but keep in your mind that the netrual and ground wires are kept separted.
#6 is very common and you should have no trouble with this but i will check with your inspector for latest issuse with ground rods it might be little diffrent other wise it pretty uniform on this issuse
Merci , Marc
