isolated ground receptacle question
Old 04-03-06, 06:47 PM
I've got some electronic equipment I'd like to put on it's own circuit and install an isolated ground receptacle. The for one receptacle seems straightforward, my question is if I want to install two receptacles in the same box, on the same circuit, can I simply connect them using the second set of screws, and if so will that receptacle also have isolated ground protection? Would I need to pigtail the ground and/or red(green) wire from the first receptacle? Or would I need a seperate circuit for that second receptacle (Can't imagine this is the case)?
If not, what is the correct way?
Thanks.
Old 04-03-06, 07:22 PM
Do not waste your money on an isolated ground receptacle for a residential setting. It will gain you nothing and cost you plenty.
Old 04-03-06, 07:29 PM
Ok, good to know. So just go with the basic grounded circuit then?
Old 04-03-06, 07:32 PM
Just run a circuit for whatever you want.
Old 04-03-06, 07:36 PM
got it thanks.
