light bulbs blowing
Old 04-05-06, 06:49 AM
L
light bulbs blowing
Hello,
I have a question about my light bulbs blowing in my house. Light bulbs in my house don't seem to last very long and I was wondering what the cause could be. I measured and I have 120 volts at the receptacles. I have even tried the long lasting bulbs to no avail. If any could help it would be appreciated.
Thank you
Old 04-05-06, 09:07 AM
I
Received 45 Upvotes on 43 Posts
Light bulbs just aren't made like they used to be; a couple months is normal with cheap bulbs. Short bulb life can be attributed to a few causes:
Vibration: Do the kids run around or roughhouse a lot shaking the ceilings and floors?
High voltage: A few companies make 130V rated bulbs; you could try those.
Is it all the bulbs in the house or just certain fixtures that seem not to last? How long do the bulbs usually last?
Old 04-05-06, 09:21 AM
F
"Standard" life for "standard" bulbs is 750 hours. PAR reflector bulbs (like in recessed lighting) have "normal" life of 1,000 to 1,500 hours. "Rough-Service" bulbs have about the same normal life as standard bulbs but they resist shaking much better. "Long-Life" bulbs will not be as bright and will be more "yellowish" than standard bulbs.
Ibpooks said it best, buy 130 volt bulbs.
Old 04-05-06, 09:46 AM
W
I have the same problem but only on my front porch fixture where we use those yellow "bug light" bulbs. I get a couple months maximum life.
Old 04-05-06, 10:51 AM
F
Approximately 700 hours in a month. If you leave your porch light on during all dark hours (photocell?) then two months of use is about normal.
Old 04-05-06, 11:02 AM
W
The photocell doesn't work, too shady. Never did the math...Thanks!
Old 04-06-06, 04:39 PM
DaVeBoy's Avatar
Most sockets in a light fixture have the wire leads attached to the aluminum socket with a brass crimp. These can fail. Remove the bulb and carefully look in the socket and see if you see blackish arcing flash marks around those 2 crimps, or any oxidation where it just doesn't look like new. If so, you have found your cause. I have had to replace many light fixtures due this cause and the call was from tenants saying their bulbs kept burning out.
