three way switch
Old 04-08-06, 01:18 PM
Baumanjohn
three way switch
Someone way back told me how to make a three way switch with a receptacle hooked into the same circuit
Has anyone done this??
thanks John Bauman
Old 04-08-06, 01:40 PM
Not much info. But if you are asking if you can use three way switches to run a receptacle, sure you can. It gets wired the same as any light circuit. You use a receptacle instead of a light fixture.
Old 04-08-06, 03:03 PM
If you are asking if you can wire a receptacle from a three way switch, the answer is maybe.
If the three way switch box has a neutral running through it then you can wire a receptacle from the box. If this switch box has the always hot end of the three way circuit (as opposed to the switched hot end of the three way circuit) then the receptacle can be always hot.
