I am trying to run 220 to my attached garage. I have a 240 volt air compressor and a Miller arc welder. What size wire will I need and what size breaker? If my existing panel is full, not sure yet, what do I need to do to start a new panel ? ThanksRead More
I just replaced all of the outlets and one switch in my bedroom. All of the outlets work but the switch does nothing. After reading through the questions in the forum I believe I need to remove the tab between the brass screws on the outlets.
My question, though, has to do with the wiring of one of the outlets and the switch. This one outlet has two black wires, two white wires and two red wires. All of the other outlets only had two black and two white wires. I connected one red wire to a brass screw, the second red wire into the hole, one black wire to a brass screw, the second black wire into the hole, and the two white wires are connected to the silver screws.
The switch had one black wire and one red wire which I connected to the brass screws. In all of the searching I have done I cannot find anything that shows red wires. Are my connections correct?Read More
