Diode, capacitors and switches Disadvantages
Old 04-14-06, 05:32 AM
Hello Guys,
I have quetions, what are the disadvantages of having so many diodes in the circuit. also, what are the disadvantages of having so many switches. moreover, what are the disadvantages of having so many capacitors. if somebody has a useful link to read it would be very helpful.
Thanks
Old 04-14-06, 05:33 AM
diode, capacitors and switches disadvantages
Hello Guys,
Thanks
Old 04-14-06, 12:14 PM
Your question is to general to answer.
The more parts you have, the more things that can go bad.
More cost.
More weight.
Larger space is required.
Old 04-15-06, 09:10 AM
Received 111 Votes on 101 Posts
Diodes and capacitors are not normal part of house wiring. They are used within different devices. You need to be more specific about "too many". Why would you use more than were required?
Old 04-17-06, 03:37 AM
Thank for the guys who read my message and special thanks for whom answered my questions.
to be more specefic, i am using a multilevel converters and this converters as you know contains 20 switches, 20 diodes and 6 capacitors. i am trying to make these converters works with less number of switches, diodes and capacitors. thats why i need to know the disadvantages or the drawbacks of having larger number of these components.
Anybody can help me more in this issue.
Thanks
Old 04-17-06, 09:04 AM
Is this a converter built by you? Or is it a converter build by a manufacturer. There's a reason that these components are installed. If you have a good understanding of electronic theory (AC and DC) you can trace the circuit and determine what each component does and how it affects the signal. Before you determine the drawback of all these components, what are you using the converters to power?
Old 04-17-06, 10:16 AM
The term multilevel converter is to general.
From your parts list, looks like your trying to build voltage doublers or dividers.
What is it that you want this converter to convert ?
Old 04-18-06, 12:35 PM
vmweenie
Thanks
I can help. Don't touch it. I have no idea what you are trying to do, nor what you are trying to do it with. Nor, apparently, do you. Simple rule for working with electrical components: If you can't design one, don't try to modify one. People get killed doing that.
Old 04-18-06, 03:42 PM
bolide's Avatar
> Don't touch it. ... People get killed doing that.
Relax. It sounds to me like this is a topic for his bachelor's thesis that his professor suggested. He probably won't get his BSEE until May 2007. He has a while to work on it.
