Electrical problem after DTV satellite installed
Old 04-17-06, 03:33 PM
A year ago we got the satellite for local TV installed by DTV and since then we've had problems with the TV blacking out when we turned on a space heater or the leaf blower - all at the TV end of the house. But I also had the radio fade out at the other end of the house when I plugged in a towel heater. Is the problem w/ the satellite pulling too much juice or should I just call an electrician? I hope someone can help me.
Old 04-17-06, 04:52 PM
Received 96 Votes on 88 Posts
Satellite pulls almost not juice. About as much as the TV.
Your problem is likely a loose connection somewhere. Are all the affected devices on the same circuit? if they are then all devices(receptacles, lights, switches, junction boxes) need to be checked.
If the problem is on multiple circuits then it could be a problem with the main power connection in your box, your meter or on the POCO side.
Old 04-18-06, 10:18 AM
Received 42 Votes on 40 Posts
It sounds like you have a problem called a "loose neutral." This can happen inside our outside of your house, and most power companies will come out and check the wiring exterior to your home for free. This is a good first step when diagnosing a loose neutral problem.
This problem is probably completely unrelated to the satellite dish installation unless perhaps the installer knocked your service wiring loose with his ladder. This is highly unlikely though. The typical cause is either high winds if the problem is outside the house or a weak connection at a receptacle that eventaully failed.
A satellite receiver uses very little power compared to a space heater or leaf blower. It is much more likely that one of those appliances is causing the problem.
If you feel comfortable working with wiring and electricity, you can troubleshoot this problem yourself. If not, you should call an electrician.
