How to wire (3) #10 awg together?
Old 04-22-06, 09:59 PM
Line into my new shed is (3) #10 awg THHN wires. It's all run in PVC conduit and will be off it's own 20 amp circuit from my garage. I know it's overkill but it's what I had on hand. After figuring out the wiring diagram for my light switch, I realize that I need to connect 3 of these wires together. I have not seen a wire nut to handle 3 #10 wires, is there such an animal? If not, what are my options here?
Thanks, this site has been invaluable to me!
Old 04-22-06, 10:06 PM
A red Ideal Wing Nut will do it fine. A grey Ideal Twister will do it more easily.
Old 04-22-06, 10:24 PM
Thanks Mac!
Old 04-23-06, 06:10 AM
Note that #10 may be too large to attach to receptacles and switches, so you may need to switch to #12 pigtails or even to using # 12 completely in the shed.
Old 04-23-06, 09:00 AM
pcboss's Avatar
If this conduit is outside or buried I hope that the wire you had on-hand was dual rated THHN/THWN. TNHHN is not rated for use in the wet environment of the conduit.
Old 04-23-06, 02:08 PM
bolide's Avatar
When people say THHN, don't they usually mean THHN-2?
Old 04-23-06, 05:38 PM
Already wired up the shed, the 20 amp receptacles take the #10 (thankfully), thanks Racraft. I have one lightswitch for an small flourescent and two 20 amp receptacles, first being GFCI. The wire does have THWN written on it, and I went by distant memory and I assumed that signified "wet", so I looked it up in my book and it's the right stuff. It is also in completely sealed PVC conduit as well.
Looking back, I would've just gone out and bought #12, it would've been easier. Amateur mistake but I did find a use for the stuff anyway.
Thanks everyone, you've been very helpful!
Old 04-24-06, 05:16 AM
ok i have to ask y do u have to nut the 3 # 10s togeather??????? and yes they do make a wire nut the will do 3 # 10 go to a electrical supply store or stop an electrical company the should sell u a few for a few cents
