Lamp Cord Question
Old 04-24-06, 06:12 AM
P
Lamp Cord Question
I'm rewireing an old lamp that has a worn out cord and when shopping for a new cord online. (I wanted a cord with a plug already molded on and it had to be clear gold color, Which I could not find in the local stores)I came acrosss two different types and I need to know which one is safer and or better to use or my older lamp
Cord Type SPT-1 or SPT-2
Old 04-24-06, 06:22 AM
R
You probably should have posted a link to the place you found these on the web.
As I see it, the only difference is that the SPT-2 is additionally listed by the C.S.A. Other than that they seem to be the same.
Supplying your location would very much help.
Old 04-24-06, 06:32 AM
P
here is the web site I found the Lamp Cords on http://www.nationalartcraft.com/cate...sp?gid=1&cid=1
Old 04-24-06, 06:50 AM
R
You still haven't listed your location, which you really should do to get the most accurate advice.
Go with whichever one you want. The SPT-2 is probably more durable, but either one is fine for a residential application.
Old 04-24-06, 07:06 AM
P
Oh I thought you meant the web site where I found the cords Sorry Iam in the USA Connecticut to be exact Thanks
Old 04-24-06, 07:58 AM
R
Change your profile so that when you post other items we will know where you are from.
Old 04-24-06, 09:00 AM
T
Received 40 Votes on 39 Posts
spt-1 is the thinnest listed plastic insulated cord available, i believe. Almost all tabletop lamps are shipped with it. SPT-2 is used with other, table top devices, including many entertainment devices, power supplies, computer chargers, etc. SPT-3 is used by clothes washers, garbage disposers, other heavy type appliances that use flat cord. I think you get the idea.
