15A vs 20A Circuit Breaker
Old 05-01-06, 05:14 PM
R
I am having a wall mounted plasma TV installed w/ a 20A transient voltage surge suppressor receptacle. The handyman I am using says that the 15A circuit breaker in my panel has to be replaced to match the 20A surge suppressor outlet. My brother is saying that the 15A circuit breaker is OK, but I would have to rewire w/ 12/2 if I replaced the 15A circuit breaker w/ a 20A circuit breaker.
Please advise!
Old 05-01-06, 05:42 PM
Speedy Petey's Avatar
True on all counts. To use this 20a device you would need to use a 20 amp breaker, requiring #12 wire.
You CANNOT simply change the breaker to 20, nor can you use the 20 amp receptacle on a 15 amp circuit.
Old 05-01-06, 06:01 PM
R
Pete,
Thanks for the reply.
I was hoping I could get by using the 20A surge supressor receptacle w/ the 15A circuit breaker, but I guess I'll have to order a 15A surge supressor receptacle.
