sub feeder service entrance
Old 05-04-06, 05:30 AM
Im wondering if there are any limitation by NEC for running service wires next to a chiney? The wires are jacketed, i know the best way to do would be to run them inside conduit.
The wire i got is 4-4-4 there are two bare copper wires inside, can i use a split bolt inside the panel and connect them to a jacketed wire for my neutral?
Can i run my bare ground and staple it to the joist or does it have to be in conduit?
Thanks Chris
Old 05-04-06, 06:47 AM
pcboss's Avatar
A three conductor cable would NOT have 2 bare wires in it.
What size is the ground wire and are you running parallel or perpendicular to the joists?
Are you trying to feed a subpanel in the same building or a detached building?
Old 05-04-06, 06:54 AM
the wire i was given to work with is 4-4-4 there are only two insulated conductors inside of it, and bare copper.
the ground wire is 6 awg
the building is attached but the panel is going to be over 100' away from the main.
Old 05-04-06, 07:51 AM
You need four conductor cable, as I stated in the other post.
