hot tub gfi gone bad
Old 05-08-06, 11:46 PM
O
I have a hot tub that i put into service the other day and it started up fine for about two hours then the 40 amp stablok gfi tripped to the off position. Normally when these trip they trip half way.When i go to energize the gfi again it always trips to the off position not trip position.Is it possible the breaker is fried as i know these things dont last.
Any help would be appreciated.
thanks
Old 05-09-06, 12:47 AM
Received 1 Vote on 1 Post
It's far more likely that there is a problem with the installation of the wiring. Two hours would be reasonable for water to get somewhere where it shouldn't and keep a ground fault somewhere.
Who did the installation?
Old 05-09-06, 12:57 AM
O
this tub was installed 13 years ago.never had a problem.I disconnected the load side of the gfi and it still trips to the off position.
Old 05-09-06, 01:11 AM
It was installed 13 years ago and put into service "the other day?" Just making sure.
GFCI breakers DO go bad; it's possible you just need to replace it, but while you have your load side disconnected check its hots and neutral to ground for continuity or resistance.
Old 05-09-06, 01:29 AM
O
thanks for the advice but like i said the breaker goes right to the off position when power is supplied not the trip position which has me puzzled.
Old 05-09-06, 08:55 AM
I
Received 44 Votes on 42 Posts
Perhaps he means, "put into service...for the summer".
Old 05-09-06, 10:35 AM
O
yes thats right it was put into service for the summer
Old 05-09-06, 12:30 PM
Yeah, I thought of that later. It was late...
