Wiring between meter socket and main breaker panel
Old 05-18-06, 07:23 PM
P
I suppose the wires need to be THHW since the socket and the main are both outdoor. I went to Lowes but the only individual wires they sell are THHN. Can I use a UF cable instead? I suppose the individual conductors are W grade since UF is for underground. Should I remove the cable sheath and use individual wires? Or use the whoe cable? Thanks in advance.
FYI: It is a 60A service.
Old 05-18-06, 08:29 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
Most wire I buy today lists as THHN/THWN. It usually is printed on the wires as "THHN or THWN"
Check it out.
Old 05-18-06, 08:35 PM
P
Thanks. I will check the print on the insulation tomorrow.
Old 05-19-06, 09:14 AM
I
Received 43 Votes on 41 Posts
No, don't use UF. The THHN at the store is probably THHN/THWN just look closely at the wire insulation.
Even though NM and UF cable are often manufactured from THHN/THWN, you can never use the individual conductors with the outer jacket of the cable removed as the conductors are not specifically labeled for that purpose. It's somewhat of a technicallity, but it's not THHN/THWN unless printed on the conductor jacket.
Old 05-19-06, 09:39 AM
If it is listed as UF what would be the point of removing the jacket?
