4-way switch bad?
4-way switch bad?
I don't do a lot of 4-way switches. Is there some special trick? The back of this Leviton says "input" on the top screws, and "output" on the bottom screws. I assume one pair of travelers is "input" and the other pair is "output." But the other 3-way switches only work when the 4-way is in one position, not the other.
Just for grins, I tried a different combo with the travelers, and same thing. Am I spinning my wheels? Is it possible that a brand new switch is just bad, or am I really showing my lack of experience with 4-way switches?
Mac :
I want to give you a quick head up with the 4 way switches some are actally double pole single throw so just watch out with this verison if getting a replacement switch make sure it marked " 4 way " not DPST set up
and also make sure you dont get travaller and common wire mixed up at 4 way switch location this will get everything screwy there .
[ it happend quite few time with some diy have to scream at my ears to get this fixed and took me a short while to figure it out ]
Merci, Marc
P.S. make sure you turn the breaker off before you fiddle around with any switches
Merci, Marc
Yeah, I did all work with breaker off. Replacing the 4-way (it WAS a "4-way") didn't work. I should have done a continuity test of each device, but that'll be next. Hopefully, it's still a bad device and not a bad traveller, now that the sheetrock is up and painted.
I have only 2 combinations (out of 8) that have the lights come on. My guess is that one of the 3-ways doesn't work. That would cause that number of combinations.
First is powered 3-way, next is the 4-way, and last is the 3-way to the lights:
dn-up-dn-on
dn-dn-dn-off
dn-dn-up-off
dn-dn-up-off
up-up-up-off
up-dn-dn-off
up-dn-dn-off
up-dn-up-on
Next test is to remove the 3-way devices and do a continuity/resistance test on them to see if one is bad.
dn-up-dn-on
dn-dn-dn-off
dn-dn-up-off
dn-dn-up-off
up-up-up-off
up-dn-dn-off
up-dn-dn-off
up-dn-up-on
Originally Posted by bolide
Switch an input with an output and try again.
Even better, tell us exactly what wires from which cables you have connected where.
> dn-dn-dn-off
good.
> dn-dn-up-off
> dn-dn-up-off
bad.
> dn-up-dn-on
good.
> dn-up-up-unknown
should be off.
> up-dn-dn-off
> up-dn-dn-off
bad.
> up-dn-up-on
good.
> up-up-dn-unknown
should be off.
> up-up-up-off
bad.
good.
> dn-dn-up-off
> dn-dn-up-off
bad.
> dn-up-dn-on
good.
> dn-up-up-unknown
should be off.
> up-dn-dn-off
> up-dn-dn-off
bad.
> up-dn-up-on
good.
> up-up-dn-unknown
should be off.
> up-up-up-off
bad.
Yeah, that much I knew. I spent some time analyzing them and figure it MIGHT be a bad 3-way, so testing those is next. The 4-way that I removed just passes a continuity test. Would a resistance test tell anything more? Would a pair of travelers shorted together cause this? I don't think so unless it opened one?
I won't bother making them dn-dn-dn-off until the whole system works. So ignore that combination and its preferred result for now, please.
If you have the 4 way out of the circuit, wire nut the travelers together (hook one in to one out and the other in to the other out). Then, try the 3 ways. If they work OK the 4 way is at fault. If not, start testing the 3 way switches.
