Outlets inside an island
Old 05-23-06, 08:50 AM
B
I'm finishing up the house I'm building and needing to put outlets in the island. What is the best way to install them?
Using a metal box and then a whip down to the floor is what I was thinking.
The cabinets are 3/4 wood. The wires are already run and hanging in the basement waiting to come up through the floor.
Thanks
Brian
Old 05-23-06, 12:22 PM
I
Received 43 Votes on 41 Posts
That sounds good to me. Just make sure the boxes are flush with the surface of the wood. NEC allows no recess of boxes into flammable material, so the box must come all the way through the cabinet wall and be flush with the surface.
Old 05-23-06, 12:35 PM
Received 1 Vote on 1 Post
I often see island receptacles on their side due to the space available. If you do this, try to orient them so that the larger hole (neutral/grounded conductor) is on the top.
