Wrong wire used
#41
Don't know if this means anything to you but just to let you know the book was shiped so when it comes I will do some reading.
#42
I would be happy to help you out, I'm not too far from warren michigan, you shoukd send me your address in a PM or something
#43
Ummmm.......Everythings up to code now right racraft. otherwise you would have said theres more to do right? I wirenutted the wire together And stapled the wire to the beam. Moved the old box so its on the same beam as the fan. Ran the wire to the old box and wire clamped it. Stapled the wire so it won't hang down. Cut the main wire down to size to make up for the old box being closer and the main wire hanging so it now runs along the rafter and is stapled. both wires run along wood and not in midair, and the old box as a metal cover on it. All wires coming a going from the box have clamps on it. Am I missing anything. If not then Im done right.?
