220v to 110v
Old 06-01-06, 03:05 PM
wes
wes is offline
220v to 110v
I am putting in a new irrigation system. I have 220v running
to the well house, where I need a 110v outlet for my Timer.
I was told I could pull 110v out of the 220v conection on the well. Is this true?? If it is, How do you do it???
Thanks
Old 06-01-06, 03:33 PM
You cannot pull 120 off a 240 feed.
You can (depending on the loads involved) pull 120 off a 120/240 feed.
Old 06-01-06, 04:30 PM
The only way you can run 120 volt off the 240 volt line is if you have full 4 wires [ HOT , HOT , NETRUAL ,GROUND ]
typically wire colour is Black , Red , White , Green or Bare wire depending on what kind wire you have there.
the safest way to do this is run a small subfeed box and have correct breaker for pump and the timer as well
if need more question just ask us here we will try to help ya
Merci, Marc
