Ground Buss
Ground Buss
Scenario:
Running wire from the house to a separate garage.
Main panel to a sub in the basement, from there to the garage sub. (I know there are guys against this--has to be done this way. Hardly anything on the basement sub so far).
Main panel 60 amp breaker, 6 gauge to sub. Sub panel 40 amp breaker, 8 gauge 8-3 type UF-B buried in 1 1/4 inch schedule 40 24 inches deep, 70 foot underground run.
Questions:
I know that I need another ground buss as the sub panel distribution box has only 1 neutral buss. Do I need stand-offs between the ground buss and the box? It would seem that I would as the ground buss would be at the same potential as the box would be. I've seen a variety of busses that you can buy, but none come with a plastic separation between them and the box.
I'm going to drive a copper grounding rod next to the garage and connect to the ground buss. I also connect the ground from the first sub to this?
How can I make this a neat installation when running the ground wire into the wall. Could I run a separate section of conduit with the ground wire in it?
What size wire should I use for the ground buss to rod?
Some guys would think that 40 amps isn't much and it isn't. But it will keep the kegerator, fan and radio going!
Questions:
Received 0 Votes
The ground bus you add to the sub panel should not have standoffs. It MUST connect to the panel. The neutral buss should have standoffs.
You need a ground rod at the garage, but it is the only connected to the garage panel. The main panel should already have it's own ground rod or other means of a ground. 8 gage protected by conduit is allowed.
Originally Posted by Don W
Scenario:
Running wire from the house to a separate garage...70 foot underground run.
The neutral bus, on the other hand, should be insulated from the subpanel box. You want to ensure there is no connection there.
