Cheap remote photocell for lazy bum
Old 06-02-06, 10:08 PM
I have an outdoor light under a metal awning that I want to control with a photocell. It's too dark under the awning for the photocell to turn off the light except in direct sunlight.
Option #1
Mount a photocell in the side of the awning and run a cord into the fixture base with a strain relief. I've seen remote photocells for lighting transformers that would do this but they seem to cost $50 or more. Is there a cheaper one somewhere?
Option #2
Mount a photocell on an existing exterior box and run wire thru existing conduit to the fixture. Not hard but I would have to clean out a closet to get at some pullboxes.
Any other options I am overlooking? Thanks.
Old 06-03-06, 08:18 AM
My cost for an 1800 watt photo cell mounted on a weatherproff cover plate is about $9. They are available in the big box/warehouse stores.
Old 06-03-06, 11:08 AM
Consider your cost for labor and materials in the second instance, and you might find the $50 worth it.
Old 06-03-06, 11:21 AM
Thanks for the responses.
I am either doing that or something else from the bottomless job jar, so the cost of my time in the real world is not really relevant. I have to take the awning off Monday so I can get a dump truck in the driveway. I don't remove it often but simpler is better. I am leaning toward running thru the conduit, which will be more work but less complicated, if that makes any sense.
