exterior spot light
Old 06-13-06, 10:21 AM
exterior spot light
im going to run an exterior spot light to light up my pond..i will tap into an outlet on my shed....is a ground need to the light ,or can i just run a white and black thhn wire ...outlet is grounded ,i will go with a a neutral wire to the light and break the hot with an exterior switch...i was told no need for ground on lights....thanks for the help
Old 06-13-06, 01:29 PM
You were told wrong.
Old 06-13-06, 04:21 PM
thanks ra...i run ground from outlet box to light box...thanks again
