Open neutral ?
Old 06-16-06, 06:33 AM
Bernard_01's Avatar
Open neutral ?
Greetings, while using a 3 prong (yellow plug in type) tester, a couple of my living room outlets showed an open neutral. At the panel the neutral is secured tightly under it's own screw as it should be. This circuit is all 12/2 NM. Am I correct to assume that there is a loose connection at one of the outlets on a side screw or even worse a poor backstab connection? Should i find the first open neutral outlet on the circuit and start there?
THANKS!
Old 06-16-06, 07:13 AM
pcboss's Avatar
Yes, you should check the receptacle just prior to the first one that shows open neutral.
Move your connections to the screw connections.
Old 06-16-06, 08:08 AM
The problem could be at the last working location or at the first non-working one. With 12 gage cable there should be no back stabs, as 12 gage won't fit back stabs.
Check all screw terminals and remake any wire nutted connections.
Old 06-16-06, 02:42 PM
ray2047's Avatar
But once up on a time there was wasn't there? I remember the first time I got one that wouldn't take 12 and being a bit disgruntled.
