Reload this Page >
Electrical Boxes mounted flush with beams rather than sheetrock - how to fix?
Old 06-16-06, 09:38 AM
When the students build my college TV studio, they mounted all the electical boxes flush with the beams rather than flush with the sheetrock. As a result, the outlets are unable to be screwed in all the way for the plates go on. When you plug something in then, the outlets push back and crack the plates (because the plates are flush with the sheetrock). Is there an easy way to fix other than re-mounting the boxes?
Old 06-16-06, 10:09 AM
pcboss's Avatar
You could try to find these at an electrical supply house.
http://www.aifittings.com/m_9.htm
Old 06-16-06, 10:15 AM
Electrical box extensions can usually be found at big box stores, always at elec supply house.
Old 06-16-06, 10:42 AM
How did this pass inspection? It's clearly a code violation.
Buy box extenders.
Old 06-16-06, 12:29 PM
Is this a commercial or public building?
This definately should have failed rough and final inspections.
