circuit breakers
circuit breakers
Do circuit breakers go bad?
What is the difference between limited and nonlimited breakers?
TIA
TIA
If you are referring to CTL vs Non-CTL breakers, (circuit tandem limiting), the difference will be a foot on the breaker to limit if and where it can be installed on the buss in the panel.
Non-CTL breakers are normally labeled for replacement use only.
