Wiring from switch box to breaker box
Ok here is the deal. I have a 60amp switch box mounted on a telephone pole next to the garage. The switch box is coming directly of the service meter. I plan on running 1 1/2 inch conduit from the switch box to a 100amp circuit breaker box in the garage. Do I need to use solid copper wire even though it will be in conduit all the way? It is an 18 feet stretch from the pole to the garage. Or can I use Aluminum? What gage wire should I also conceder?
Thanks,
Jim D
Thanks,
Jim D
