Low voltage lighting
Old 07-02-06, 07:23 PM
Can I hook up two separate wires to the screws on the transformer, to run a set of lights in each direction, or do I need two separate transformers?
Old 07-02-06, 07:27 PM
nap's Avatar
nap
nap is offline
New Member
You can hook up as many wires as you want but you need to be sure you do not put on more lights than the transformer can supply without burning out.
The transformer should have a rating on it either in amps or VA. If it is amps, we need input or output amps and the voltage both high and low and what wattage your lights are.
Old 07-02-06, 07:28 PM
rpt
rpt is offline
You can run two sets. The only thing you have to do is add up the wattage of all of the lights you're going to use and make sure that the transformer will handle the total wattage.
