Recessed Outlet for twist-lock plug
Old 07-03-06, 12:54 PM
I am looking for recessed outlets (clock receptacles) for a single twist lock male plug and also a single standard outlet.
A part number would be good.
Thanks in advance.
Old 07-03-06, 03:41 PM
pcboss's Avatar
What voltage and ampacity do you need?
Old 07-03-06, 06:12 PM
Kinda dumb not to include that, 15 amp 115 volt. I really need two. One for a standard grounded plug, like a Leviton 688-W, and the other for a single male twist lock, two wires plus ground.
thanks for the reply
Old 07-03-06, 09:35 PM
Recessed, Probaley won't find one. Recessed why? Twist lock why? The cord cap won't be that small either.
Old 07-04-06, 08:06 PM
I thought I could duplicate this for less than the $299.00 price tag
http://www.panamax.com/products.cfm?...il&id=261&ly=h
The picture loads a little slow. The twist lock cord plugs into the back a power conditioner. This system is used to provide conditioned power to plasma tv that is hung on the wall and the power (romex) cable is in the wall.
I plan on using only a single box inplace of the duplex box and will use flex-conduit to help keep stray noise down.
Old 07-04-06, 08:51 PM
power conditioners are not cheap. A twist lock won't give you conditioned power. You could locate a conditioner in the basement feed it, Then run the load to the TV.
Old 07-04-06, 09:01 PM
The conditioner is about the size of a stero receiver and sits in the area with all the stero gear and cable box.
Here is a full here is a full layout of the system, with the 5500 being the conditioner.
http://www.panamax.com/Literature/PDF/INS0736E.pdf
I am not going to run the TV signal lines in the same box as the power.
Old 07-05-06, 11:18 AM
Why does the twist-lock one need to be recessed?
Old 07-05-06, 01:15 PM
If there is a back on the equipment cabinet, which there is, the plug will extend from the receptacle and prevent the cabinet from being positioned against the wall.
I have all the parts except the recessed twist lock. As soon as I find a big electric warehouse I should be able to get one.
