Recess light ring hanging
Old 07-15-06, 07:14 AM
Anandtd
Hi,
I noticed that one of our recess light ring is hanging a bit off the celing. Of course that doesn't look good. And also i hear somewhere that it could leak our cool air into attic and puts unnecessary burden on the a/c unit.
Now what to do to reseat the ring. (should i be using some adhesive to put it back?) or is it a ring that i should just screw in .. it didn't look like that though.
Old 07-15-06, 07:26 AM
majakdragon's Avatar
I am not the expert here but most I have seen either have tabs that hold them into the ceiling or a spring ring that holds it to the fixture. Good luck and watch this post for the experts answers.
Old 07-15-06, 07:37 AM
pull the trim down, you will see how it is held in. Either by springs or tension wires, These may need to be tweaked a little to re snug the trim.If it is a texured ceiling, you may take a small putty knife and smooth out under the ring.
Old 07-25-06, 04:04 PM
Anandtd
Thank you very much. It was easy ... two springs that i had to reset. Appreciate your help.
Old 07-25-06, 04:21 PM
THANK YOU!
It's nice to hear back how a project came out or if advice was usefull.
