steel bars of building
Old 07-25-06, 01:02 PM
hex boy's Avatar
Question steel bars of building
I've used steel bars of building as grounding. is it ok?
Old 07-25-06, 01:07 PM
What are you grounding?
For an equipment ground the answer is NO.
For the requirements for grounding electrode, it must be one of the things you ground. You still must bond the water and the ground rods as well as the building steel.
Old 07-25-06, 01:30 PM
hex boy's Avatar
thanks jwhite.
yes an equipment ground (an ACU).
Old 07-26-06, 03:12 AM
Use a full size equipment ground conductor, or metal racways and fittings that are listed for grounding.
