PVC IN Wall? -- Removing Zinsco Breaker
Old 07-28-06, 02:35 PM
ray2047's Avatar
Two quick questions. Is PVC conduit not permitted by the NEC for use in enclosed wall spaces even for short (less then 3") distances?
I have an old Zinsco box I will need to remove breakers from. There is a red metal bar about 3/4" wide that appears to run across the top of all the breakers. Am I correct in believing the bar must be removed to pull breakers? It appears to be held by a metal tab on each end. How is it removed? The only way I can see is to pry one side away from tab.
To beter identify the Zinsco box it has four tandem breakers arranged horizontally and no main breaker.
Old 07-28-06, 08:32 PM
Wink
yes you can use pvc INSIDE the walls (not a firewall or fire retardant wall right?)
about the breaker never seen it
Old 07-28-06, 09:21 PM
ray2047's Avatar
Thanks. I was a bit confused by another post that said PVC couldn't be used indoors but your emphasis on "inside" cleared it up for me.
