Air Conditioner Plug Gets Warm??
Hello Everyone: I had a friend who is a qualified electrician and has died, put a seperate line in for my 5000BTU air conditioner in my bedroom.
Is it normal for the plug and the receptacle to be warm (not hot) just warm? I am a senior citizen with a Heart condition and really need to have this in this heat wave! But I dont want to burn the house down YET! Thanks, Tom
I think there is no doubt that I can keep my hand on it all day, It does not seem to get hot just warm, but I will keep an eye on it during the night If its the same warmth in the morning then I guess its should be ok, right?
Well I believe Speedy mentioned first, it was the higher draw when I first turned it on the plug and receptical got a little warm but as the thermostat kicked in to a lower position, it got completely cold and seemed to stay that way all night and it kiced off and on as it should have. So I guess everything is ok and normal. Thank you ALL, Tom
Tom,
You can make the text of any web page appear larger by going to the "View" menu at the top of Internet Explorer. Select "Text Size" from the drop-down menu and the options "Larger" and "Largest" will appear to the right.
If you use Firefox, Mozilla or Netscape: hold down the Ctrl key and simultaneously press the + (plus) and - (minus) keys at the far right side of your keyboard.
{font size=4} your text here {/font}
By replacing the { and } with < and >
...you get:
your text here
Adjust the number for larger or smaller.
A 5 font is:
your text here
...you get:
your text here
A 5 font is:
your text here
Ibpooks, already have that set to largest!
Speedypetey, you said>>
...you get:
your text here
A 5 font is:
your text here
I dont get what you are saying, need to walk me thru it?
...you get:
your text here
A 5 font is:
your text here
I'm not sure if I understand what you are trying to do.
Do you need all the text on the page larger so you can read it?
Or are you trying to make your own posts larger?
#21
Well, what I would like to do is make my words larger, and maybe others can make them the same as mine. I am not seeing as good as I use to and it strains my eyes to type and read these words.
#22
I agree with ipbooks then. Your best bet is to make the whole page larger.
You say you did that already but I suspect you are not going large enough.
You can make the text quite large.
I definitely would NOT rely on others to follow your lead with large text. Besides, you still will not see the large text doing it my way until the post is made. You still see it smaller while typing.
#23
I have this at its largest. Besides this will not enlarge this forums it only enlarges IE.
Most forums besides the color, bold etc. also have a size change option at the top of the reply (composing) screen, but this site does not. Thanks, anyway
