Installing Accent Light on the ceiling
Hi, I am planning to add an additional accent light on my kitchen. Currently, I only have one and would like to add at least 3 to 4 more lights. My dilemma is running the wires. I think cutting a round hole on the ceiling is not a problem bu running those wires to each of these hole is a puzzle to me. As much as possible, do not want to cut or break the walls just for me to see or run the wires. Can you advise me if there is an easy way to install additional lights on the ceiling, particularly on locating the holes to run the wires to. Thank you, I appreciate it.
I'm not exactly sure what you are doing here. You bring up walls but then don;t really xpalin why they would be involved.
So, you want to instal some new lights, right?
Are they going to be on the same switch as the current lights?
Do you have an attic above the kitchen?
Basement below the kitchen?
Just trying to get some general info.
Kind of lost on that :
part as well.
explain your intent a bit and answer the questions above and we will give you all the help we can.
part as well.
part as well.
Sorry guys, this is a brand new house but unfortunately they only installed one accent light. I want to add more at least 4-5 more using the same switch. This is a two story house and no attic above the kitchen. I guess my question is how will I run the wires after putting the holes? I am trying to avoid too much damage on the ceiling besides making holes. Is there kind of tools like a snake to run the wires through the holes? And, what is the best tool to cut the hole? Any tips is greatly appreciated. Thanks.
If the new lights are in line with the old lights, and if the joists run the same way, then you may be able to simply pass the wires from one light to the next. However, if the joists run perpendicular or you have to cross them then you have no choice but to make holes in the ceiling and patch them later on.
There are many devices designed to cut drywall. The cheapest method is to use a hacksaw blade in a handle. More expensive methods include various cutting devices. Check at the hardware stores.
