Grounding
Grounding
I am replacing a wall switch for a combo ceiling fan/light, additionally, there is a second switch for a wall light in the same wall box.
There is no grounding wire in the wall box, but one is attached to the combo switch.
My questions is, does this switch need to be grounded. If so, what is the safest way to do this?
I live in a 6 unit town house built in 1989.
Thanks for your help,
Can I assume metal boxes? If so, a 1989 install would have definitely mandated grounded boxes. In this case nothing needs to be done. The switch is grounded through the screws to the grounded box.
box ground
If there is a bare or green wire as part of the cable entering the box, that's the ground. Being connected to the switch the box is also grounded (if metallic, that is) when the switch is fastened in.
Grounding
Thank you for the "Speedy" response.
The Green ground wire is attached to the new switch. And the wall box is metallic.
Based on your responses, this switch will already be grounded at the metal wall box and there is no need to attach the ground wire.
Thank you,
Thank you,
