Electrical box stripped nut...
ok. I'm far from technical when it comes to the electrical lingo. I'm attempting to put a ceiling fan up in my bedroom. I was hanging the mounting bracket, and I think I stripped the one of the nuts in the box that I was attempting to mount it to.
Is my only option to go out and get another box? Or is there a way to repair the "nut"? Any suggestions would be appreciated.
You can repair the hole with an epoxy such as J B Weld. If you haven't used it before, you mix two parts from two tubes to make a small amount of the epoxy. After you fill the hole with a small amount of epoxy, let it dry completely for about 24 hours. Then you can drill a small hole to start the screw.
I had this same problem with electrical outlets a year ago and got the answer on this site. It worked great!
So, are you saying I should get a new electrical box then, craft? I agree that I would be a little nervous using epoxy for this ceiling fan. It is pretty heavy. Could it be as simple as using a slightly smaller screw and connecting to a loose nut?
Thanks all for the input.
Is this a metal, plastic or fiberglass box you are mounting to?
If it's metal, go ahead and drill out the hole and buy a 10/24 screw and nut to fit.
If it's plastic or fiberglass, I would replace the box with a new one that is specifically rated for fan support. Fan rated boxes will specifically say so on the packaging, and it will often be stamped onto the box also.
It is a metal box and it is pretty secure. I will attempt to drill a bigger hole, as I've found there is enough room to do it safely.
Thanks all for your help and your concern. I really appreciate it!!
You may not even need to drill it out. You can replace the screw that stripped just in case it's threads were also messed up with one of the same size and put a nut on the back side. I'd probably use a lock nut. (That's a nut with a nylon insert to keep it tight despite vibrations.)
Of course if it isn't a fan grade box might be a good time to upgrade. They are easy to install.
Just wanted to update you'all and let you know that as of last night, the fan is securely spinning from my ceiling. I ended up drilling a slightly larger hole, and voila! The screw screwed in there securely and the fan is working like a champ. Thanks again to all that helped me.
