Should I replace the sevice panel
House has a 35 year old Federal Pacific breaker panel. I was thinking about replacing the panel but I discovered most and probably all the problems are in the connections. Some of the high current connections get pretty warm(110F with a lazer probe). Tightening has helped some but the wires still look pretty corroded. What is the best way to clean wire and terminals. I was considering using a blitz cloth and some cramolin red. Well I have already done this on the HVAC circuit and temp of the wire went from 110 down to room temp.
Yes.
You may want to look at the link about Federal Pacific panels.
http://www.inspect-ny.com/fpe/fpepanel.htm
I knew they had problems but never knew they were this bad. Is there a replacement for the breakers, I undestand this is not the case but thought I would ask. Replacing a panel wouldnt be that bad of a job. Unfortunately I have 3 of them to replace. This would also explain the melt down the breaker had when the well pump went bad. I thought it was lightning damage fortunately for me so did the insurance co.
