Receptacle Height in Garage ?
Old 08-06-06, 06:56 AM
SF49erfan's Avatar
Hi Guys.....Great site with excellent information.
I was wondering what height my receptacles need to be in my detached garage. I've heard 40" and 48" ....Also, do I need just one GFCI outlet or should they all be GFCI protected ? Thanks a lot. Tony.
Old 08-06-06, 07:02 AM
Speedy Petey's Avatar
I use 48".
All readily accessible (ie: the ceiling is not considered readily accessible) 120v, 15 & 20 amp receptacles must be GFI protected. They do not all have to be GFI devices.
Old 08-06-06, 07:09 AM
They can be whatever height you want. But if they are readily accessable they must be gfi protected.
Old 08-06-06, 10:12 AM
When I wired my garage I put everything at about 4 ft off the floor. I dont think there is a code rquirng this but it is a handy hiegth. Garages havw a tendency to become cluttered so make sure you put a couple of outlets in places they would never be blocked. I have twelve outlets in my garage and I think I may have ready acces to 4 of them with out moving something. Ive found just inside doors usually stays pretty clear, an outside outlet is nice too.
Old 08-06-06, 02:25 PM
SF49erfan's Avatar
Outlet Height
Thanks for your input guys. I appreciate your help. - Tony.
Old 08-06-06, 02:47 PM
Hellrazor's Avatar
Figure out your ideal workbench or cabinet height and add 4-6". That way you set up your garage as a shop or whatever in the future without a problem.
