Do I need special cans for outdoor recessed lighting?
Old 08-08-06, 08:36 PM
dcolucci's Avatar
Question Do I need special cans for outdoor recessed lighting?
Do I need special cans for outdoor recessed lighting? Or can I use standard "old work" cans? Any recommendations-I want the widest spread of light I can get.
Old 08-08-06, 08:46 PM
Sthrnamp's Avatar
"old work" cans?
Hey,
If you could define "old work" can's that might help.
I install all kinds of cans everyday on rear decks of homes. The important factors you need to consider are:
1) Does the branch circuit allow for the wattages of the cans?
2) Is the ceiling insulated above where the cans will be installed?
Basically, make sure insulation isn't within 3 inches of the cans and that adding the cans won't over load the circuit.
Lemme know if this doesn't answer your questions..
SthrnAMP
Old 08-08-06, 09:01 PM
dcolucci's Avatar
old work defined
By old work I mean "remodel" type cans. (Although, since the cans would be installed in the attic, I guess I could use new type cans.)
Old 08-09-06, 04:06 AM
Speedy Petey's Avatar
"Old work" is a very common term for remodel cans.
No, there are usually no outdoor specific cans and trims. Most are damp rated.
Outdoors is only damp rated. A shower or steam bath would be wet rated.
