GFI- fault when it rains
Old 08-24-06, 02:52 PM
I have a GFI circuit that has an exterior pond on it. This pond circuit has a pump and light. Ive now seen that when it rains hard the GFI trips. When it dries out, the GFI will reset.
I see no visible water entry into anything.
Can anyone give me an idea of where to begin to debug this?
Thanks
Gary
Old 08-24-06, 03:37 PM
Does it trip even with the pump and light unplugged?
If so, start with the receptacle. Water is getting somewhere.
Old 08-24-06, 06:54 PM
Thanks
Gary
Is the equipment plugged directly into the tripped GFCI receptacle, or is the equipment on a receptacle at some distance on the LOAD (pass-thru) side of the GFCI receptacle or on a GFCI breaker? Is the circuit in PVC conduit, rigid, or via UF cable? If the tripped GFCI is upstream, there could be an insulation fault.
Are you using a weatherproof-while-in-use cover? Is the cover oriented properly and latched? In a driving rain enough water may get in to cause a ground fault.
