Is this a big deal? (Electrical outlet removal)
We are planning knock out part of a wall to create a doorway. In the middle of that wall is an electrical outlet. Is it a big deal to take out the outlet and the wiring that goes with it? Can we just cut the power off and cut the wires, or is that a ridiculous question? Is this a job best left to a professional?
Thanks.
Thanks.
First, find out exactly where the outlet gets it's power. It may be from another outlet plus it may pass power on to other outlets. Pull the receptacle and see how many wires are in the box. If there are more than two plus a copper ground, you may need an electrician to move this circuit. Check and let us know what you find. Don't forget to cut the power at the breaker before you go into the receptacle box.
You may also need to add new receptacle in order to meet the spacing requirements when you add the doorway.
They should be no more than 6' from either side of the new door.
Really? To cut a hole in a wall to make it a pass through requires a permit? We don't live in a city, but we are in police jurisdiction. I can't imagine needing a permit, but I'll check. Thanks for the heads up.
Problem is that if you cut the wrong studs you could weaken the roof or second floor. You don't want the police, along with EMT's digging you out of the rubble.
Just to set the record straight, you may or may not need a permit. It all depends on where you live. I used to live in a place where you did not need any permits unless you were modifying the foundation. I've found on a number of web forums that many people who live in or near "the big city" automatically think that the entire country needs permits to change a door knob.
That said, permit or not, you need to understand what you are dealing with, and your questions make it sound like perhaps you should consult a professional.
First, no you cannot just cut the wires, I assume you don't like fires starting in the wall, further, even if you could, code would not allow you to conceal them, they would have to terminate in a junction box. Further still, as already mentioned, that outlet may not be the last on the circuit and you would need to deal with the downstream outlets/fixtures. At best case, you'd need to go disconnect the line coming to that box from whatever box it is originating. Worst case, you need to rewire the downstream outlets/fixtures. Also, as mentioned, you may have spacing issues with required outlets by code, and structural issues if the wall in question is weight bearing.
Thanks guys, but this may be a job for professionals. Doorknobs, light switch plates and ceiling fans we can do - electrical, not so much.
Thanks for the advice thought. It is greatly appreciated.
