15a GFI on 20a line
Old 09-09-06, 05:45 PM
15a GFI on 20a line
Hi-
12-2NM in garage. 15a GFI protecting 3 20a rated receptacles.
Is this OK? I know the GFI's protection has nothing to do with the 15a rating, just the rating on the receptacle itself.
Thanks. Ray.
Old 09-09-06, 06:00 PM
This is fine, as far as the GFCI is concerned.
I hope that the NM cable is protected in some way. Many inspectors won't allow NM cable in a garage unless it is either in the ceiling or protected.
Old 09-09-06, 08:08 PM
Yes racraft-all is inside walls. Thanks once again for your time and knowledge!
Ray.
Old 09-11-06, 10:06 AM
Received 1 Vote on 1 Post
The code basically says you can have 15 amp receps on a 20 amp circuit, unless it is a single, dedicated recep, then it must be rated 20A.
But a 20A recep may not be used on a 15 amp circuit.
Old 09-11-06, 08:09 PM
Is this OK?
Is this a 15A GFCI breaker protecting the circuit, or a 15A GFCI receptacle protecting some downstream receptacles, all on a 20A circuit?
Old 09-12-06, 12:20 AM
Mac702-
Sorry should have been more explicit-
It is a 15a GFCI protecting downstream recepts. The breaker is a standard 20a. All the NM is 12-2.
Thanks to all!
ray
Old 09-12-06, 12:45 AM
Receptacle rating revisited
I don't understand the logic of allowing a 15a rated recep on a 20a line. My logic (probably faulty) says that any OCPD protects downstream components (i.e. wiring and receps). To me it seems as though this is purely a thermal issue (plastic jacketing around wires and wood next to NM cable will burn before the actual copper wire). If this is so, why does the code allow a 15a rated recep on a 20a line? As an example, even in a multiple recep NM run, if I only happen to be using one of those receps, and the load on that recep is 19a (not enough to trip the breaker), would not that recep exceed it's thermal rating (and get overheated) before the thermal rating on the NM cable is exceeded? Lets take the reverse- I have a 15a breaker with 14-2 NM. Why can I not have a 20a rated recep on that line? If I draw a 17a load on that circuit, it seems to me that the OCPD will trip and protect the lowest capacity component (the 14-2 NM) will be properly protected. The recep in this case does not overheat. The only problem I can see is placing an inapropriate OCPD (i.e. 20a breaker on a 14-2 line) in a circuit.
Hope I didn't open up a can of worms!
Ray.
Old 09-12-06, 12:53 AM
15A and 20A receptacles are basically identical in construction. It's just the pin configuration that sets them apart.
All the ones I know of will pass 20A with no problems, especially the GFCI receptacles.
Old 09-12-06, 12:57 AM
Why can I not have a 20a rated recep on that [15A] line?
Because then one should be able to assume that a 20A load is okay, when they see a 20A receptacle.
Old 09-12-06, 01:40 AM
thanks mac702!
Old 09-12-06, 10:05 AM
With a 20 amp breaker and 12-2 NM cable, you are certainly permitted to replace any and all 15A receps with 20A rated receps. Just not required. It is very common to have all 15A receps on a 20 amp general purpose lighting and receptacle circuit. The 20A models are a bit more expensive, and few homeowners have corded appliances and tools that draw over 15 amps. Exceptions would be, say, a window air conditioner, or a commercial power tool. (I had a 1 HP table saw once. Draws 16 amps and had a 20A plug. Had to upgrade a circuit just so I could use it.)
