Measuring voltage between ground and rod
Old 09-25-06, 07:55 AM
I was hooking up a grounding rod to my trailer.
I got a small zap.
I checked again and it only happened if a small cut on my hand touched it. If anyone has ever played with 9v batteries you know the same is true for them also, if you touch it to a cut you get the same type of zap.
I measured it and it is reading about 7.5v, dont know what amp.
I checked and most of it seems to be from a monitor. I unplug the monitor and it drops to 2v.
Is it normal to have a small amount of voltage running like that when things are plugged in?
Mike
Old 09-25-06, 08:06 AM
Describe this setup further.
Why are you hooking up a ground rod to a trailer? What is the entire setup?
Old 09-25-06, 08:35 AM
Because I need to ground the dwelling.
Trailer as in trailer home.
Mike
Old 09-25-06, 08:53 AM
In most areas you need two ground rods six feet apart.
As for the tingle, I have this spot on my had that when the end of something like a wire touches it, it feels just like an electrical tingle. I think it has to do with the nerve endings.
To be safe, turn off power, at the main to the trailer stansioin while hooking up the ground rod.
Old 09-25-06, 09:07 AM
Make sure that you have the ground and neutral properly bonded at the main disconnect.
