50 amp gfi breaker problem (originaly posted by bharris)
Old 09-26-06, 07:43 PM
Unhappy GFI Problem
I installed a new aux panel with a double 50 GFI for a hot tub.
I cannot get the test button to pop out. (There is no "re-set" button. Any help. Thanks.
Old 09-27-06, 01:28 AM
bharris, I moved your post to a new thread. New questions should start a new thread because it makes it easier for others to follow the board.
Old 09-27-06, 01:38 AM
To reset a GFI breaker turn it all the way off then back on, as you would any other breaker.
Old 09-27-06, 04:39 AM
If the GFCI breaker will not reset then you don't have it wired properly (or you have a bad breaker). Is there any load yet, or is the circuit just run with no load? Is the neutral properly connected to the breaker and not to the neutral bar?
