Main breaker question
Old 09-28-06, 04:52 AM
If I tap off a 200 amp main panel to a 100 amp load center can I have a 100 amp 2 pole breaker in the main panel, and a 100 amp main breaker in the 100 load center? is this legal?
Old 09-28-06, 04:56 AM
Yes, provided that the cable or wire between the panel can handle the 100 amps.
Old 09-28-06, 04:46 PM
You do not need a main breaker in the sub panel.
You will need 4- wires between the two panels (rated for 100 Amps).In the sub, keep the neutral and ground isolated.
Assuming these panels are within the same structure.
Old 09-28-06, 05:32 PM
william tell's Avatar
no main in sub if less than 6 cir .
other wise yes unless you can see it AND its less than 50 ft. away
Old 09-28-06, 05:36 PM
nap's Avatar
nap
nap is offline
New Member
Huh?
The six movement rule applies to the main service only and the visable and less than 50 feet applies to disconnects for equipment.
A sub does not need a main breaker if it is within the same building, as lectriclee posted.
