Overhead conduit support cables
Old 09-28-06, 05:21 PM
I went with an overhead service and had to make it quite high because of the pool. Anyway, I have two cables supporting the riser as it goes 15' above the roof, one at the 4' level and another at about 12'. Is this sufficient? Both are in the same plane and opposite the utility's connection at the weatherhead. Did they need to be triangulated?
Old 09-28-06, 05:26 PM
Speedy Petey's Avatar
Only your utility can answer this with any certainty, but it sounds like you are fine.
