New Ground (Electrical Wiring)
Old 09-30-06, 04:30 PM
New Member
I need to run a new ground wire for my main breaker panel. I bought some #8 copper a couple of years ago and have a 69' section and a 27' section left. For the panel I'll probably need 40' or so. I also need about 50 feet for something else (lightning rod).
Am I allowed to join two sections of the ground wire as long as I leave the joint accessable?
Thanks.
Old 09-30-06, 05:08 PM
william tell's Avatar
No, it must be unbroken
Old 09-30-06, 05:49 PM
New Member
OK, thanks. I'll do what I need to do so it is right.
Old 09-30-06, 07:19 PM
L
Depends, What size service? Lightning, two different items.
Old 09-30-06, 08:10 PM
New Member
[QUOTE=lectriclee]Depends, What size service? Lightning, two different items.[QUOTE]
200 Amps
Old 09-30-06, 08:30 PM
L
Sorry, #8 is too small. You need #4.
Old 10-01-06, 03:47 AM
Just a thought, but it might be cheeper and easier to just drive a new ground rod near the panel.
Old 10-01-06, 07:55 AM
New Member
I mistyped, it is #4. I think the original is #8, not sure.
Anyway, I probably can put in a new grounding rod near the panel. What do I need to do so a new grounding rod for my main panel is up to code?
Old 10-01-06, 08:14 AM
I just re-read this thread and I need to back up a step. Why did the panel move? I am asking because if an addition was put on that required a footing, some areas of the country are already using the ufer ground rules. (comming soon in the 2008 code everyone will be requred to do this)
I may have misunderstood what ground wire you were trying to extend. If your house is served by metal water line, either to the city supply or your own well, then this metal pipe must be used as your primary grounding electrode. If that pipe is way at the other end of the house, then you still have to run a ground wire to it.
In addition to the water pipe you need at least one ground rod. I do not think the rod is required if you use a ufer ground, I may be wrong. That ground rod is easiest to install if you keep it near where the service comes into the house.
If you do not have metal water lines, then you probably need two ground rods. There is a rule for testing the resistance of one rod, but IMHO it is cheeper to drive a second rod than to do the proper test.
Please post back with what the situation is at your house, so that we can better advise you as to your specific needs.
Jeff
