Home Electrical Panel
Old 10-06-06, 02:31 PM
R
Hi, my name is Lynn. My question is I have a 200 amp panel with a 50 amp subpanel. I found out today from a friend that I have over 108 amps in use with just the A/C and a Mr. Steam on the subpanel of 50 amps. What is the solution? Thanks, Lynn
Old 10-06-06, 03:39 PM
Speedy Petey's Avatar
Solution for what?
Old 10-06-06, 04:38 PM
W
I am with Pete. You question is unclear. Are you saying that you have 108 amps on the 50 amp panel? How did you friend get the 108 amps?
Old 10-06-06, 05:18 PM
Received 238 Votes on 209 Posts
Are you tripping the 50 amp breaker for the sub panel? The solution is to replace the 50 breaker, the cable to the sub panel and the sub panel with a larger one or to move the loads to the main panel from the sub panel.
