Outlet below breaker box, ok to do?
Old 10-13-06, 05:33 PM
Is it ok to put a 240 outlet(for welder) about 2 feet below my breaker box in the garage, or does this break code? Thanks in advance!
Old 10-14-06, 11:10 AM
OK, I know this is an uninteresting post, but we're gonna do this in a couple of hours, and if anyone know if this is okay to do, the info would be greatly appreciated. Thanks!
Old 10-14-06, 11:29 AM
I do not see any problem with this.
Old 10-14-06, 01:04 PM
ray2047's Avatar
If you can run through the wall NM is ok. If surface mount run EMT (AC would probably be acceptable also).
Old 10-14-06, 04:33 PM
Just don't park the welder in front of the panel. You still need to keep the 30" x36" area clear directly in front of the panel.
