Wiring Router Table
Old 10-14-06, 03:31 PM
Wiring Router Table
I have a home made router table with a portable router attached. I want to wire this to my table with the proper switch and outlet attached to the table so I can unplug it or switch it off right at the table. Is it safe to buy a switch/outlet combo at the hardware to do this with or should I have a special switch /outlet for this?
Old 10-14-06, 03:40 PM
Assuming that the reouter has a normal cord and plug then, yes, you can buy a combination switch/receptacle for this.
You could surface mount a handy box and install the device in there, and use a SO type cable with a plug on the end that plugs into a normal receptacle for power. Alternately, you could install a junction box recessed into the side of the table and install the device, wiring in the same manner as described above.
